Team Associated B6.1 & B6.1D thread >
Like Tree1089Likes
    Hide Wikipost
Old 03-24-2020, 06:21 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6.1 & B6.1D thread
Last edit by: Kraig
Welcome to the B6.1 and B6.1D Wiki page.
Features:
Easy-access gear differential
Differential height adjustment with 0, 1, 2, and 3mm inserts included
New slipper assembly for better weight balance and shock clearance
3-gear Laydown Stealth(r) transmission for lower and forward CG
Heavy-duty V2 routed graphite front shock tower with tower guard
Heavy-duty V2 routed graphite rear tower, standard height
Heavy-duty V2 rear axle with 67mm bones
V2 springs for a more reactive and nimble feel
Innovative rear arm with molded inserts for ultra-fine lower shock mount adjustment
Molded spur gear guard to help protect body from damage
Front and rear anti-roll bars limit chassis roll for increased corner speed
Battery strap allows the use of optional turnbuckle-based braces
Machined pistons included for better fit and smoother operation
Aluminum rear clamping hex and front axle with laser etching
Rear hubs feature large bearings and the easy-insert system to adjust camber link position and rear axle height
One-piece shock bushing to make assembly easier
Aluminum C and D arm mounts included for large range of anti-squat and toe adjustment
Lightweight aluminum top shaft
Factory Team upgraded ball bearing kit included (now oiled instead of greased for less drag)
JConcepts(r) B6 clear body and wing included
Steel chassis weight
Shortened, 7075 aluminum chassis
Features:
Easy-access ball differential
3-gear Lay Back Stealth(r) transmission for lower and rearward CG
Heavy-duty V2 routed graphite rear tower, long
+1 steering block arms optimize feel on dirt tracks
Setup Sheets and other documentation
Setup sheets for both cars:
Piston Drills:
Aftermarket Upgrades:
Parts List:
Reference Guides (courtesy of Ray Munday and Roger M.):
Print Wikipost
Old 02-10-2018, 08:47 AM
D1360's Avatar
Default delete
See Wiki for up to date car and aftermarket part information.
Last edited by b1narych0ice; 02-25-2018 at 09:55 PM. Reason: keeping thread for now
D1360 is offline
Old 02-10-2018, 09:28 AM
gticlay's Avatar
Trader Rating: 14 (100%+)
Originally Posted by D1360
Is there a releasedate yet? Can they be pre-ordered anywhere?
Yes, here's some info at least for Canadian hobby shops. https://shop.hi-performance.ca/index...ducts_id=51924
gticlay is offline
RazorRC's Avatar
We need a thread for the new b6.1 and b6.1d.
Well done sir 👍
RazorRC is offline
Old 02-10-2018, 10:43 AM
sea1swk's Avatar
Am I the only one who immediately thought, Truck Parts!
sea1swk is offline
D1360's Avatar
https://www.facebook.com/JConcepts.I...6217995118216/
Evoking1230 and e-fanatic like this.
D1360 is offline
Old 02-10-2018, 02:05 PM
D1360's Avatar
Is this the new diff?
Big_Show likes this.
D1360 is offline
Old 02-10-2018, 02:56 PM
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
woot! good luck d1360 with first post duties!
RCBuddha is offline
Old 02-10-2018, 03:13 PM
Trader Rating: 16 (100%+)
A-Main has them listed.
Still Bill is offline
Old 02-10-2018, 03:19 PM
Yes.
Assume there is a new ball diff too.
Old 02-10-2018, 04:15 PM
Originally Posted by TC5Driven
I agree. Why not just keep this with the B6 and B6D thread???
With so many component changes between the B6 and B6.1 chassis and the new V2 springs, the setup sheets will vary significantly between the two versions. So, I agree with the need for two separate strings.
Honestly, I would have called the new car a B7...which should have resulted in a new string anyway.
Old 02-10-2018, 04:23 PM
Big_Show's Avatar
From what I am getting the diff will interchange. MIP just released their 6 series diff early December and discontinued the 5 series. I believe AE would of gave MIP a heads up, I mean VRP already has a shock tower prototype already, think they could of had it that fast without word from AE.
Big_Show is offline
Old 02-10-2018, 07:04 PM
olds45512's Avatar
I have a 6.1d on order from my local supplier, can't wait to get my hands on it!
olds45512 is offline
Old 02-10-2018, 07:06 PM
olds45512's Avatar
Why would AE tell anybody anything? Every part you buy from someone else is money your not spending with them so it's not in their best interest to help other manufacturers.
Old 02-10-2018, 07:27 PM
Big_Show's Avatar
MIP and AE have a very long close relationship. I doubt either party wants to ruin that.
mdwaeracer and Latino277 like this.
Big_Show is offline
Old 02-10-2018, 08:11 PM
Suspended
It's called a working relationship. AE can sell more cars if aftermarket companies make cool stuff people want to buy to go on said car. AE doesn't even make light weight driveshafts, a big portion of MIP's business. I want to say JC had bodies available right when the B6 dropped. Don't be surprised if JC had a new B6.1 body when it drops. Shoot, AE basically got the B44 from JConcepts. The industry is small, and AE recognizes the value in strong aftermarket support.
urnotevenwrg2 is offline
